When starting Microstation, this error message pops up and will not let me into the program. any ideas. I have removed the program, shut down the computer. After restarting the computer and reinstalling
the latest version of Microstation from the Bentley website, the error message comes up again>
Seems it is related to SEWERGEMS configuration and not to Microstation.
Rick Saunders said:When starting Microstation
You're not starting just MicroStation: you're starting StormCAD. Its SEWERGEMS configuration is incorrectly configured: it's missing a folder, as the message tells you.
..\MicroStation\config\appl
Hi Rick,
You need to post this type of thread in Hydraulic and Hydrology forums communities.bentley.com/.../haestad-hydraulics-and-hydrology-forum
You can also review this wiki https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/8560/troubleshooting-microstation-integration
Maria
Maria Garcia
Hello Rick,
Could you please follow troubleshooting steps mentioned in below wiki for the mentioned error? Please let us know if that helps or not.
Troubleshooting MicroStation integration
Sushma Choure
Bentley Technical Suppport
I agree with Sushma - as seen in the article, we have seen this issue before in cases where the MicroStation version was upgraded after the OpenFlows product was integrated. Re-running the Integrator shortcut (from the Start menu) should fix this. If that does not help, try the other troubleshooting steps in the article.
Answer Verified By: Rick Saunders
