is it possible for me to set up the report so my flushing report will zoom in to each step closer so i can see which hydrant on what street is flushing?
Hello Michelle,
After computing the flushing events, in the report views you can set up multiple secondary views where you can select hydrants of your interest as part of that report view. You can rename the report views that to hydrant labels to ease out identifying them.
Conducting Flushing Studies in WaterGEMS and WaterCAD
Look for report view topic in this
Sushma Choure
Bentley Technical Suppport
Hi Sushma,
I think my issue is that when I zoom into the flushing report map, the pixel degrades. previously I was able to zoom in and see the street name.
Thank you,
Michelle
Hi Michele,
What version of WaterGEMS are you using?
See: Flushing operators report graphic or background is blurry in the print preview
If this does not help, please provide a copy of the model for review and reply with the name of the file and exact steps to reproduce: Sharing Hydraulic Model Files on the OpenFlows Forum
