time browser default
Is there a way to set the default or start time for the time browser? I would like to review my model at time 730 minutes. Each time I run or change pipes I have to select that time again. Can it be the default or a bookmark?
Thanks.
SewerGEMS Connect latest edition
  • Brian, we are checking with our product development team to see if this would be feasible to add in a future release. Thanks for your suggestion.
    Jesse Dringoli
    Bentley Systems, Inc.
  • Brian, I have submitted enhancement request #797041 to our product development team to add an option to prevent the Time Browser from resetting to zero upon re-compute. I suspect part of the reason it does not do this already is because of the possibility of the selected timestep no longer being valid when re-computing. For example say you had used a timestep of 0.5 hours and were looking at timestep 10.5 hours and you recompute the model with the timestep set to 1.0 hours.
    I also noticed you mentioned you are seeing this happen when you "change pipes" - can you elaborate on that? If you mean simply clicking on another pipe to see its properties, I cannot reproduce this (the Time Browser retains its time position for me, at least in a sample file).
    Jesse Dringoli
