WaterGEMS Tank Controls to Fully Refill Tank Model Problem
Hi All,
I am working on a fairly basin WaterGEMS model that includes a tank. Based on the junction demands, the tank HGL reduces over time. I have a control set where the tank will start to refill when the HGL has dropped by 5 feet. The tank will then stop refilling when it is full. I have a problem with my control set because the tank refill shuts back off again when it reaches the 5ft drop elevation. I need it to continue filling until it is full. See snippets below of my tank properties and the control added. I am thinking I need to adjust my control so that the model knows to keep the tank filling until full.
Parents Reply Children
