For reference, have looked at previous answers including the following:
https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/54400/pressure-and-pressure-head-what-are-the-differences
https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/101425/what-is-the-difference-between-pressure-and-pressure-head/301194#301194
However, it still is not clear to me on the relationship between the two. For instance in the attached Image, the Minimum Transient Pressure is -98kPa while the Minimum Transient Head is 1677.76. What is the relationship there?
If my pipe has a PN16 Pressure Rating, which of the two should i refer to in order to know whether or not the pressures are Okay.
