Questions
I have a few questions:
  1. So if I understand the concept of Customer meter elements correctly you can use them in order to more accurately assign the customer demands to nearby nodes without having to incorporate the pipes that connect to the customer meters in to your model. But then the I find myself wondering the following:
    If my license allows me to model with a limit of 2000 pipes is that then really 2000 pipes or is that 2000 elements. So is it:
  • all my pipes, nodes customer meter elements etc together can’t be more than 2000
  • or can I have 2000 pipes plus the nodes and elements attached to them and then also some customer meter elements for example.
  1. The X and Y coordinates that are mentioned are those the same as latitude and longitude coordinates? So let’s say I have the longitude and longitude of my customer meters along with the demand at those meters will load builder and modelbuilder properly place the subsequent customer meter elements and demands based on the latitude and longitude? I do not understand how the x and Y coordinate system in WaterCAD works and how I check to see if ccordinates of junctions that I bring in for example with t-rex will come in with the right x-y ccordinates
  1. When using thiessen Polygon generation would you have to draw the outer surface polygon before or after running the generator?
  1. I wanted to know if I understood the concept of the GIS ID correctly. So from my understanding an element (pipe for example) is given an ID in the GIS source and when you import the elements form the GIS source that pipe comes in to WaterCAD with that ID attached to it. The pipe in the WaterCAD model and the GIS database are then linked through the ID so that when a change is made in the waterCAD model (say for example the c-factor of the pipe ) it automatically updates the pipe in the GIS database. Unless the ID of the element has been lost through for example skeletonization of the WaterCAD model.
  • 1. Laterals do not count against the license. These can be used to help keep the number of pipes in the model lower. More information can be found here: Is there a criteria for selecting a pipe limit when purchasing WaterGEMS or WaterCAD? Inactive pipes do not count against the license either.
    2. WaterCAD standalone does not use a coordinate system and latitude and longitude are not reported. If you use a Bing Maps background layer, you could get the latitude and longitude from there. See this link for more information: Reporting model element latitude and longitude.
    The X and Y coordinates can differ based on how the model was created. If you used ModelBuilder or added a background before adding pipes manually, the X and Y coordinates will be based on the source file. As an example, if you have a shapefile and use ModelBuilder to build a model with this, the X and Y value for the end of a pipe will be the same as the value in the shapefile being used. If a model was built like this and you elevation data for TRex is in the same coordinate system in the GIS, the model and the elevation file will likely line up. If it doesn't, you may need to reproject the model or the source file.
    3. Thiessen Polygons are generated automatically around nodes in the system. This is primarily used for some of the LoadBuilder methods. You can find more information on the properties of this in the Help documentation.
    4. Since more than one element can have the same GIS-ID, you should be able to maintain this if you skeletonize the model. The following links have some information that may be useful:
    Tips for improving performance of all-pipe models linked to a GIS
    Keeping a Hydraulic Model in Sync with a GIS
    When you are using ModelBuilder to build a model, you have options to use Label or GIS-ID as the key field as well. More information on this can be found at the following link: Using ModelBuilder to Import External Data.
    Scott
Reply
    Scott
