I'd like to know if there is a way to select an entire group of nodes with the same demand pattern. I have a model with several patterns, so I want to select all the nodes of each pattern that I have. Is there any way... Thanks in advance.
Best regards
Carlos
Carlos,
You had posted in the "Everything Else" forum which is intended for topics unrelated to Bentley products. I have moved your post to the OpenFlows forum which is the best place to ask questions about OpenFlows products.
Selecting elements based on demand pattern can be accomplished in the Demand Control Center:
This Wiki article was created to help with this the next time it is encountered.
Thanks,Larry
Don't forget that there might be several different types of node elements which contain the pattern (junctions/hydrants/etc). They each have different tabs in the Demand Center so you would have to filter each tab separately and add them to the selection set you created on the first node element type.
Jesse,
Thank you very much for the information. I was doing it similar, but the part of "Filter is the one that I was missing. Very helpful.
Best regards.
Thanks Larry,
I think it will be very helpful for anybody with the same problem
Carlos Bellido
