SWMM output File units
I couldn't solve the specific units required for the SWMM output summary. I read all your posts,still couldn't figure it out. Th swim output file comes as CFS units. Kindly arrange a tutorial for it.For information, I m using the latest version of Bentley SewerGems.
  • Hello Ahmed,
    In the below example, the flow units are set to L/s using Tools > options > units or using element properties.
    When we compute the model in the SWMM output summary the unit is displayed as CFS initially, however flow values are reported in units specified while modeling i.e. L/s. Can you confirm if same is in your case as well?
    See below wiki for more details.
    Units in SWMM output reports
    Sushma Choure
    Bentley Technical Suppport
Reply
  • Hello Ahmed,
    Sushma Choure
