Found line article. I am looking to import arcs as a background for a roadway. I am using a dgn. Is this possible yet?
DXF or Shapefile background not showing even with zoom extents - OpenFlows | Water Infrastructure Wiki - OpenFlows | Water Infrastructure - Bentley Communities
Brian, while we look into this, can you let us know if you have attempted to use a DGN background and encountered a problem? If so, can you provide a copy of the DGN using either of the methods described here? Please also confirm the version number of SewerGEMS and StormCAD that you are using.
Attached is the dgn used as a background. We are using the latest version of connect. 10.03.04.53
Plan-Pavt.dgn
Hello Brian,
The DGN file appears to load as a background layer for me. I compared the background layer to the DGN's appearance in MicroStation and it looked the same. If there is some issue you are seeing, please let us know.
Scott
See the attached pdf for what I am seeing.
PDF
If I zoom in, I see something similar, at least using StormCAD standalone. This may be a decent approximation for modeling purposes. However, if there is some requirement where you need to display the background as an arc, could you use StormCAD for MicroStation instead of StormCAD standalone? If I open your DGN in StormCAD for MicroStation, it appears to display the arcs and this would allow you to add StormCAD elements similar to if you were loading the DGN as a background layer.
