WaterGEM - Model Builder Sync Out
I have imported the GIS shapefiles in to WaterGEMS. It has single pipe with unique GIS ID as shown in 1st image. Then I have used the batch split option and split it into multiple pipes with spatial joining to all valves and nodes (newly created).
Now I want to "Sync out" in the model builder and update the flow and pressures to the required pipes. But the single pipes are split into four units (with common GIS ID).
If I want to sync the required flow details from one particular pipe (from one of the four pipes) to the one in the GIS shapefiles, is there any method?
