Hi there.
I come from the pumping industry in Australia and trialing the use of SewerCAD at the moment, we use steady-state modeling via excel sheets and also some of the other modeling tools available in the market.
I have gone through the exercises available on Youtube and also from your learn server, where it doesn't actually represent a real-life problem, the pump curves are not just available for a project as you show, and in most cases, for a model it is the responsibility of the designer to choose the pump/s with the help of suppliers, for this, the designer is expected to provide a duty point ie. flow and required head.
please see attached for a simplified real-life problem where we are required to work the pump duty point so we can select a pump. We can do this in various other ways as I have mentioned above and what I want to please know is how to tackle this from SewerCAD. How would you model a system to work out the pump's duty point without placing the pump?
PDF
explanation of the scenario:
we have a wet well and the pump sets are submersible centrifugal sewer pumps.
the incoming gravity pipework is 225mm Ductile Iron pipework, ID is 240mm. The peak incoming flow is 12L/s, and our requirement is the match this flow via the pump selection. ie. the pump flow rate has to be min 12L/s. The levels are provided in the model and based on this flow rate we have selected the forced main as 125mm PE100 PN16 (ID is 102mm)
In some of the other modeling tools, we can place the pump as a fixed flow pump and when we run the model it would develop the required duty point.
while searching about this topic, I had come across this: https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/16879/estimating-a-pump-curve-for-a-model but not too sure if this works or not.
your help in this regard is appreciated and believe this will help many.
Cheers,
Imran
The overall steps work like this.
There are other considerations of course such as whether to use a submersible or dry pit. For a small station like this, a submersible is typical.
Then there is type of impeller. A closed, multi-vane impeller is usually the most efficient. However, it is the most likely to clog with solids and rags. Depending on the type of solids you expect, you may want to favor an open impeller with fewer vanes for wastewater.
Hi Tom,
appreciate your response to this,
I am quite familiar with everything except item #3, I am not sure how to model this in SewerCAD without giving the pump curve, if you or someone could explain this that would be beneficial. Thanks in advance
Correct, we normally go with Flygt N type impellers, and we ensure the riser and rising main all sized to max particle size comes through the impellers. To our specs, the riser has to be min 80mm in dia. and the rising main (force main) to be of min 100mm in ID.
For step 3, make sure the calc option is set to GVF-Convex. Create a pump definition (Components) for one of your candidate pumps into the pump definition for this model scenario. Run the model to make sure the results are reasonable. Right click on the pump and pick System Head Curve. Pick the compute button in the system head curve dialog.
