my seniors and I were working on small coastal model. We have everything set up good, and while running the model it suddenly stopped in the middle of the process and showed us the following error: forrtl error (73) floating divide by zero. Any idea how to fix it? we cant seems to find any solution online regarding this particular software.
Thank you kindly
Hello Aliep,
There can be various reasons for this to occur. Could you please provide more details regarding your model setup?
You can export the workspace following these instructions (please don't select the option to include results) and then upload the OWS file as described here.
Thank you very much and kind regards,Luis
