My model is giving me this error and I can't get it to do anything else. I tried all the troubleshooting from another discussion question in the forum similar to this but nothing. I also have the updated version of WaterGEMS.
Thank you Scott keep me updated.
Hi Andrea, your model fails to compute or validate because of an issue with the configuration of the hydropneumatic tanks HT-1 and HT-2. You have configured the model to run a steady state simulation but still consider simple controls (the calculation option "Use simple controls during steady state" is set to "true"), and there are simple controls active to control the pump status based on the HGL of the hydropnematic tanks, but the HGL range does not match the HGL range in the tank properties. The controls refer to an on HGL of 208 ft and an off HGL of 247 ft, but difference values are entered in the tank properties "HGL (on)" and "HGL (off)".
To resolve the issue, set the controls equal to the HGL on/off values, or choose "False" for "use simple controls during steady state". For example set the HGL on to 208 ft and the HGL off to 247 ft and the model will validate and compute.
I will report this issue to our developers for better handling in a future version, and will document this in our Wiki in the meantime.
One slight correct to my previous post - in addition to fixing the HGL on/off values so that they match the controls, it appears that you will also need to go to Components > Controls, then click through each of the four controls at the bottom of the list (related to the tanks), then close the controls dialog and the model should validate. (at least, this is what I needed to do in the latest version, 10.03.05.05).
I have reported this to our developers (reference #877038) and added my solution as item #6 in this article: User Notification "Failed to validate model"
Thank you Jesse Dringoli this ran my model! I appreciate it greatly.
On the other hand,
How would you recommend inputting TCEQ criteria for ground storage tanks/booster pumps/ hydropneumatics tanks?
