I hope you are doing well. I am a student of Civil Engineering and was given a task to design a water supply network for a colony using WaterGems so I imported the layout of the colony in (dxf) format in WaterGems using model builder when I tried to make a network of pipes, I get to know that the length of the each pipe is way more than it should be. I tried to get help from the software help center but found nothing. So it is requested here to kindly let me know how to set the scale of the drawing in WaterGems?
Thanks.
Dear Sir,
Thank you so much for helping me and giving me your precious time. My problem got solved. My classmates were also getting the same problem and we were stuck and worried about this task as the deadline is near so once again thank you for helping me out.
