I am using Civil Storm for Autodesk Civil 3D 2022. I want to set up conduit library to reflect Wis DOT bid item schedule. The storm sewers are classified by pipe wall thickness, i.e. Class II, Class III, etc.
Each pipe size in each class has a separate bis item #. (See attached. The end result needed is how to show bid item # in Flex table so each # can be totaled (length). I am also enclosing the xml file.
<NewDataSet><HMIModelingElement><Id>1</Id><LibraryElementType>1</LibraryElementType></HMIModelingElement><HMIModelingElement><Id>3</Id><LibraryElementType>1</LibraryElementType></HMIModelingElement><HMIModelingElement><Id>4</Id><LibraryElementType>1</LibraryElementType></HMIModelingElement><HMIModelingElement><Id>5</Id><LibraryElementType>1</LibraryElementType></HMIModelingElement><CatalogConduitLibrary><Id>1</Id><Guid>141a2c1a-8517-44fd-a9a5-0d6d7e385720</Guid><DateModified>2022-05-11T11:35:17-05:00</DateModified><ElementID>46</ElementID><Label>Class II</Label><Notes /><CatalogConduit_Material /><CatalogConduit_AvailableForDesign>false</CatalogConduit_AvailableForDesign><CatalogConduit_Manufacturer /><CatalogConduitShape>0</CatalogConduitShape><CatalogConduitRise>0</CatalogConduitRise><CatalogConduitSpan>0</CatalogConduitSpan><CatalogConduitRoughnessType>0</CatalogConduitRoughnessType><RoughnessDepthCurveCount>0</RoughnessDepthCurveCount><RoughnessFlowCurveCount>0</RoughnessFlowCurveCount><ClassSizeCollectionCount>20</ClassSizeCollectionCount></CatalogConduitLibrary><CatalogConduitLibrary><Id>3</Id><Guid>44c99aba-b951-41b2-91ab-85fa185b817d</Guid><DateModified>2022-05-11T11:24:30.4902775-05:00</DateModified><ElementID>0</ElementID><Label>Class III</Label><Notes /><CatalogConduit_Material /><CatalogConduit_AvailableForDesign>false</CatalogConduit_AvailableForDesign><CatalogConduit_Manufacturer /><CatalogConduitShape>0</CatalogConduitShape><CatalogConduitRise>0</CatalogConduitRise><CatalogConduitSpan>0</CatalogConduitSpan><CatalogConduitRoughnessType>0</CatalogConduitRoughnessType><RoughnessDepthCurveCount>0</RoughnessDepthCurveCount><RoughnessFlowCurveCount>0</RoughnessFlowCurveCount><ClassSizeCollectionCount>0</ClassSizeCollectionCount></CatalogConduitLibrary><CatalogConduitLibrary><Id>4</Id><Guid>aed9a797-3d95-4a58-92d4-17a533b43cba</Guid><DateModified>2022-05-11T11:24:51.2852413-05:00</DateModified><ElementID>0</ElementID><Label>Class IV</Label><Notes /><CatalogConduit_Material /><CatalogConduit_AvailableForDesign>false</CatalogConduit_AvailableForDesign><CatalogConduit_Manufacturer /><CatalogConduitShape>0</CatalogConduitShape><CatalogConduitRise>0</CatalogConduitRise><CatalogConduitSpan>0</CatalogConduitSpan><CatalogConduitRoughnessType>0</CatalogConduitRoughnessType><RoughnessDepthCurveCount>0</RoughnessDepthCurveCount><RoughnessFlowCurveCount>0</RoughnessFlowCurveCount><ClassSizeCollectionCount>0</ClassSizeCollectionCount></CatalogConduitLibrary><CatalogConduitLibrary><Id>5</Id><Guid>c354fd87-80c9-459a-900f-6cfecea51497</Guid><DateModified>2022-05-11T11:25:38.228199-05:00</DateModified><ElementID>0</ElementID><Label>Class V</Label><Notes /><CatalogConduit_Material /><CatalogConduit_AvailableForDesign>false</CatalogConduit_AvailableForDesign><CatalogConduit_Manufacturer /><CatalogConduitShape>0</CatalogConduitShape><CatalogConduitRise>0</CatalogConduitRise><CatalogConduitSpan>0</CatalogConduitSpan><CatalogConduitRoughnessType>0</CatalogConduitRoughnessType><RoughnessDepthCurveCount>0</RoughnessDepthCurveCount><RoughnessFlowCurveCount>0</RoughnessFlowCurveCount><ClassSizeCollectionCount>0</ClassSizeCollectionCount></CatalogConduitLibrary><CircularPipe><Id>1</Id><CatalogConduitDiameter>0</CatalogConduitDiameter></CircularPipe><CircularPipe><Id>3</Id><CatalogConduitDiameter>0</CatalogConduitDiameter></CircularPipe><CircularPipe><Id>4</Id><CatalogConduitDiameter>0</CatalogConduitDiameter></CircularPipe><CircularPipe><Id>5</Id><CatalogConduitDiameter>0</CatalogConduitDiameter></CircularPipe><PipeArch><Id>1</Id><PipeArchType_FullArea>0</PipeArchType_FullArea><PipeArchType_BottomRadius>0</PipeArchType_BottomRadius><PipeArchType_CornerRadius>0</PipeArchType_CornerRadius><PipeArchType_TopRadius>0</PipeArchType_TopRadius><PipeArchType_BottomDistance>0</PipeArchType_BottomDistance></PipeArch><PipeArch><Id>3</Id><PipeArchType_FullArea>0</PipeArchType_FullArea><PipeArchType_BottomRadius>0</PipeArchType_BottomRadius><PipeArchType_CornerRadius>0</PipeArchType_CornerRadius><PipeArchType_TopRadius>0</PipeArchType_TopRadius><PipeArchType_BottomDistance>0</PipeArchType_BottomDistance></PipeArch><PipeArch><Id>4</Id><PipeArchType_FullArea>0</PipeArchType_FullArea><PipeArchType_BottomRadius>0</PipeArchType_BottomRadius><PipeArchType_CornerRadius>0</PipeArchType_CornerRadius><PipeArchType_TopRadius>0</PipeArchType_TopRadius><PipeArchType_BottomDistance>0</PipeArchType_BottomDistance></PipeArch><PipeArch><Id>5</Id><PipeArchType_FullArea>0</PipeArchType_FullArea><PipeArchType_BottomRadius>0</PipeArchType_BottomRadius><PipeArchType_CornerRadius>0</PipeArchType_CornerRadius><PipeArchType_TopRadius>0</PipeArchType_TopRadius><PipeArchType_BottomDistance>0</PipeArchType_BottomDistance></PipeArch><BoxPipe><Id>1</Id><BoxPipeType_BoxRise>0</BoxPipeType_BoxRise><BoxPipeType_BoxSpan>0</BoxPipeType_BoxSpan></BoxPipe><BoxPipe><Id>3</Id><BoxPipeType_BoxRise>0</BoxPipeType_BoxRise><BoxPipeType_BoxSpan>0</BoxPipeType_BoxSpan></BoxPipe><BoxPipe><Id>4</Id><BoxPipeType_BoxRise>0</BoxPipeType_BoxRise><BoxPipeType_BoxSpan>0</BoxPipeType_BoxSpan></BoxPipe><BoxPipe><Id>5</Id><BoxPipeType_BoxRise>0</BoxPipeType_BoxRise><BoxPipeType_BoxSpan>0</BoxPipeType_BoxSpan></BoxPipe><TrapezoidalChannel><Id>1</Id><TrapezoidalChannelType_BottomWidth>0</TrapezoidalChannelType_BottomWidth><TrapezoidalChannelType_RightSideSlope>0</TrapezoidalChannelType_RightSideSlope><TrapezoidalChannelType_LeftSideSlope>0</TrapezoidalChannelType_LeftSideSlope></TrapezoidalChannel><TrapezoidalChannel><Id>3</Id><TrapezoidalChannelType_BottomWidth>0</TrapezoidalChannelType_BottomWidth><TrapezoidalChannelType_RightSideSlope>0</TrapezoidalChannelType_RightSideSlope><TrapezoidalChannelType_LeftSideSlope>0</TrapezoidalChannelType_LeftSideSlope></TrapezoidalChannel><TrapezoidalChannel><Id>4</Id><TrapezoidalChannelType_BottomWidth>0</TrapezoidalChannelType_BottomWidth><TrapezoidalChannelType_RightSideSlope>0</TrapezoidalChannelType_RightSideSlope><TrapezoidalChannelType_LeftSideSlope>0</TrapezoidalChannelType_LeftSideSlope></TrapezoidalChannel><TrapezoidalChannel><Id>5</Id><TrapezoidalChannelType_BottomWidth>0</TrapezoidalChannelType_BottomWidth><TrapezoidalChannelType_RightSideSlope>0</TrapezoidalChannelType_RightSideSlope><TrapezoidalChannelType_LeftSideSlope>0</TrapezoidalChannelType_LeftSideSlope></TrapezoidalChannel><IrregularChannel><Id>1</Id><IrregularChannelType_LeftBankStation>0</IrregularChannelType_LeftBankStation><IrregularChannelType_RightBankStation>0</IrregularChannelType_RightBankStation><OpenChannelWeightingMethod>0</OpenChannelWeightingMethod><IrregularChannelCollectionCount>0</IrregularChannelCollectionCount></IrregularChannel><IrregularChannel><Id>3</Id><IrregularChannelType_LeftBankStation>0</IrregularChannelType_LeftBankStation><IrregularChannelType_RightBankStation>0</IrregularChannelType_RightBankStation><OpenChannelWeightingMethod>0</OpenChannelWeightingMethod><IrregularChannelCollectionCount>0</IrregularChannelCollectionCount></IrregularChannel><IrregularChannel><Id>4</Id><IrregularChannelType_LeftBankStation>0</IrregularChannelType_LeftBankStation><IrregularChannelType_RightBankStation>0</IrregularChannelType_RightBankStation><OpenChannelWeightingMethod>0</OpenChannelWeightingMethod><IrregularChannelCollectionCount>0</IrregularChannelCollectionCount></IrregularChannel><IrregularChannel><Id>5</Id><IrregularChannelType_LeftBankStation>0</IrregularChannelType_LeftBankStation><IrregularChannelType_RightBankStation>0</IrregularChannelType_RightBankStation><OpenChannelWeightingMethod>0</OpenChannelWeightingMethod><IrregularChannelCollectionCount>0</IrregularChannelCollectionCount></IrregularChannel><RectRoundChannel><Id>1</Id><RectRoundChannelType_RectBottomRadius>0</RectRoundChannelType_RectBottomRadius></RectRoundChannel><RectRoundChannel><Id>3</Id><RectRoundChannelType_RectBottomRadius>0</RectRoundChannelType_RectBottomRadius></RectRoundChannel><RectRoundChannel><Id>4</Id><RectRoundChannelType_RectBottomRadius>0</RectRoundChannelType_RectBottomRadius></RectRoundChannel><RectRoundChannel><Id>5</Id><RectRoundChannelType_RectBottomRadius>0</RectRoundChannelType_RectBottomRadius></RectRoundChannel><RectTriangleChannel><Id>1</Id><RectTriangleChannelType_RectTriangleTriangleHeight>0</RectTriangleChannelType_RectTriangleTriangleHeight></RectTriangleChannel><RectTriangleChannel><Id>3</Id><RectTriangleChannelType_RectTriangleTriangleHeight>0</RectTriangleChannelType_RectTriangleTriangleHeight></RectTriangleChannel><RectTriangleChannel><Id>4</Id><RectTriangleChannelType_RectTriangleTriangleHeight>0</RectTriangleChannelType_RectTriangleTriangleHeight></RectTriangleChannel><RectTriangleChannel><Id>5</Id><RectTriangleChannelType_RectTriangleTriangleHeight>0</RectTriangleChannelType_RectTriangleTriangleHeight></RectTriangleChannel><PowerChannel><Id>1</Id><PowerChannelType_PowerExponenet>0</PowerChannelType_PowerExponenet></PowerChannel><PowerChannel><Id>3</Id><PowerChannelType_PowerExponenet>0</PowerChannelType_PowerExponenet></PowerChannel><PowerChannel><Id>4</Id><PowerChannelType_PowerExponenet>0</PowerChannelType_PowerExponenet></PowerChannel><PowerChannel><Id>5</Id><PowerChannelType_PowerExponenet>0</PowerChannelType_PowerExponenet></PowerChannel><IrregularClosedSectionPipe><Id>1</Id><ElevationWidthCurveCount>0</ElevationWidthCurveCount></IrregularClosedSectionPipe><IrregularClosedSectionPipe><Id>3</Id><ElevationWidthCurveCount>0</ElevationWidthCurveCount></IrregularClosedSectionPipe><IrregularClosedSectionPipe><Id>4</Id><ElevationWidthCurveCount>0</ElevationWidthCurveCount></IrregularClosedSectionPipe><IrregularClosedSectionPipe><Id>5</Id><ElevationWidthCurveCount>0</ElevationWidthCurveCount></IrregularClosedSectionPipe><ConstantRoughness><Id>1</Id><ConstantRoughnessType_ManningsN>0</ConstantRoughnessType_ManningsN><ConstantRoughnessType_KuttersN>0</ConstantRoughnessType_KuttersN><ConstantRoughnessType_DarcyWeisbachE>0</ConstantRoughnessType_DarcyWeisbachE><ConstantRoughnessType_HazenWilliamsC>0</ConstantRoughnessType_HazenWilliamsC></ConstantRoughness><ConstantRoughness><Id>3</Id><ConstantRoughnessType_ManningsN>0</ConstantRoughnessType_ManningsN><ConstantRoughnessType_KuttersN>0</ConstantRoughnessType_KuttersN><ConstantRoughnessType_DarcyWeisbachE>0</ConstantRoughnessType_DarcyWeisbachE><ConstantRoughnessType_HazenWilliamsC>0</ConstantRoughnessType_HazenWilliamsC></ConstantRoughness><ConstantRoughness><Id>4</Id><ConstantRoughnessType_ManningsN>0</ConstantRoughnessType_ManningsN><ConstantRoughnessType_KuttersN>0</ConstantRoughnessType_KuttersN><ConstantRoughnessType_DarcyWeisbachE>0</ConstantRoughnessType_DarcyWeisbachE><ConstantRoughnessType_HazenWilliamsC>0</ConstantRoughnessType_HazenWilliamsC></ConstantRoughness><ConstantRoughness><Id>5</Id><ConstantRoughnessType_ManningsN>0</ConstantRoughnessType_ManningsN><ConstantRoughnessType_KuttersN>0</ConstantRoughnessType_KuttersN><ConstantRoughnessType_DarcyWeisbachE>0</ConstantRoughnessType_DarcyWeisbachE><ConstantRoughnessType_HazenWilliamsC>0</ConstantRoughnessType_HazenWilliamsC></ConstantRoughness><RoughnessDepth><Id>1</Id><BankChannelType_LeftManningsN>0</BankChannelType_LeftManningsN><BankChannelType_ChannelManningsN>0</BankChannelType_ChannelManningsN><BankChannelType_RightManningsN>0</BankChannelType_RightManningsN><BankChannelType_LeftHazenWilliamsC>0</BankChannelType_LeftHazenWilliamsC><BankChannelType_ChannelHazenWilliamsC>0</BankChannelType_ChannelHazenWilliamsC><BankChannelType_RightHazenWilliamsC>0</BankChannelType_RightHazenWilliamsC><BankChannelType_LeftDarcyWeisbachE>0</BankChannelType_LeftDarcyWeisbachE><BankChannelType_ChannelDarcyWeisbachE>0</BankChannelType_ChannelDarcyWeisbachE><BankChannelType_RightDarcyWeisbachE>0</BankChannelType_RightDarcyWeisbachE><BankChannelType_LeftKuttersN>0</BankChannelType_LeftKuttersN><BankChannelType_ChannelKuttersN>0</BankChannelType_ChannelKuttersN><BankChannelType_RightKuttersN>0</BankChannelType_RightKuttersN></RoughnessDepth><RoughnessDepth><Id>3</Id><BankChannelType_LeftManningsN>0</BankChannelType_LeftManningsN><BankChannelType_ChannelManningsN>0</BankChannelType_ChannelManningsN><BankChannelType_RightManningsN>0</BankChannelType_RightManningsN><BankChannelType_LeftHazenWilliamsC>0</BankChannelType_LeftHazenWilliamsC><BankChannelType_ChannelHazenWilliamsC>0</BankChannelType_ChannelHazenWilliamsC><BankChannelType_RightHazenWilliamsC>0</BankChannelType_RightHazenWilliamsC><BankChannelType_LeftDarcyWeisbachE>0</BankChannelType_LeftDarcyWeisbachE><BankChannelType_ChannelDarcyWeisbachE>0</BankChannelType_ChannelDarcyWeisbachE><BankChannelType_RightDarcyWeisbachE>0</BankChannelType_RightDarcyWeisbachE><BankChannelType_LeftKuttersN>0</BankChannelType_LeftKuttersN><BankChannelType_ChannelKuttersN>0</BankChannelType_ChannelKuttersN><BankChannelType_RightKuttersN>0</BankChannelType_RightKuttersN></RoughnessDepth><RoughnessDepth><Id>4</Id><BankChannelType_LeftManningsN>0</BankChannelType_LeftManningsN><BankChannelType_ChannelManningsN>0</BankChannelType_ChannelManningsN><BankChannelType_RightManningsN>0</BankChannelType_RightManningsN><BankChannelType_LeftHazenWilliamsC>0</BankChannelType_LeftHazenWilliamsC><BankChannelType_ChannelHazenWilliamsC>0</BankChannelType_ChannelHazenWilliamsC><BankChannelType_RightHazenWilliamsC>0</BankChannelType_RightHazenWilliamsC><BankChannelType_LeftDarcyWeisbachE>0</BankChannelType_LeftDarcyWeisbachE><BankChannelType_ChannelDarcyWeisbachE>0</BankChannelType_ChannelDarcyWeisbachE><BankChannelType_RightDarcyWeisbachE>0</BankChannelType_RightDarcyWeisbachE><BankChannelType_LeftKuttersN>0</BankChannelType_LeftKuttersN><BankChannelType_ChannelKuttersN>0</BankChannelType_ChannelKuttersN><BankChannelType_RightKuttersN>0</BankChannelType_RightKuttersN></RoughnessDepth><RoughnessDepth><Id>5</Id><BankChannelType_LeftManningsN>0</BankChannelType_LeftManningsN><BankChannelType_ChannelManningsN>0</BankChannelType_ChannelManningsN><BankChannelType_RightManningsN>0</BankChannelType_RightManningsN><BankChannelType_LeftHazenWilliamsC>0</BankChannelType_LeftHazenWilliamsC><BankChannelType_ChannelHazenWilliamsC>0</BankChannelType_ChannelHazenWilliamsC><BankChannelType_RightHazenWilliamsC>0</BankChannelType_RightHazenWilliamsC><BankChannelType_LeftDarcyWeisbachE>0</BankChannelType_LeftDarcyWeisbachE><BankChannelType_ChannelDarcyWeisbachE>0</BankChannelType_ChannelDarcyWeisbachE><BankChannelType_RightDarcyWeisbachE>0</BankChannelType_RightDarcyWeisbachE><BankChannelType_LeftKuttersN>0</BankChannelType_LeftKuttersN><BankChannelType_ChannelKuttersN>0</BankChannelType_ChannelKuttersN><BankChannelType_RightKuttersN>0</BankChannelType_RightKuttersN></RoughnessDepth><ClassSizeCollection><RowID>1</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>c5590e3c-74db-49c2-90c9-fd7bc1c73518</ClassSizeCollection_Guid><ClassSizeCollection_Label>12 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>1</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>2</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>f94de844-60d8-4d83-971e-72490badea7d</ClassSizeCollection_Guid><ClassSizeCollection_Label>15 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>1.25</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>3</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>253a9307-75ea-41de-a0d6-0e86b7cdbd20</ClassSizeCollection_Guid><ClassSizeCollection_Label>18 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>1.5000000000000002</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>4</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>f9450fa6-331a-42df-b597-7fcdcc49cd51</ClassSizeCollection_Guid><ClassSizeCollection_Label>21 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>1.7500000000000002</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>5</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>bcdc6d52-0d64-4ebc-b196-29e2457fd17e</ClassSizeCollection_Guid><ClassSizeCollection_Label>24 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>2</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>6</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>869216ae-72d4-4baa-bebb-9d6fddb3e66d</ClassSizeCollection_Guid><ClassSizeCollection_Label>27 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>2.25</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>7</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>c10b415d-ab3b-4af8-bc0b-7f1250adecd4</ClassSizeCollection_Guid><ClassSizeCollection_Label>30 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>2.5</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>8</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>e52ddc58-7c7a-4a3b-8521-36089a3a5402</ClassSizeCollection_Guid><ClassSizeCollection_Label>36 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>3.0000000000000004</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>9</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>98ea154c-cb82-4a99-9caf-a17b266799d3</ClassSizeCollection_Guid><ClassSizeCollection_Label>42 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>3.5000000000000004</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>10</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>13ed54be-b48b-4623-9626-6ece1bcfabf2</ClassSizeCollection_Guid><ClassSizeCollection_Label>48 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>4</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>11</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>2323c0e3-833d-4f26-a55e-81cca9627cd6</ClassSizeCollection_Guid><ClassSizeCollection_Label>54 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>4.5</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>12</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>4a860e26-ed72-4075-8806-4f81b8451df1</ClassSizeCollection_Guid><ClassSizeCollection_Label>60 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>5.3333333333333339</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>13</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>37bf651e-dbed-429e-b4a3-6e44f8494c03</ClassSizeCollection_Guid><ClassSizeCollection_Label>66 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>5.5</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>14</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>fd4dacdb-977e-4715-8634-0ecd1cd81434</ClassSizeCollection_Guid><ClassSizeCollection_Label>72 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>6.0000000000000009</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>15</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>6eb9ea4e-a1cf-4ed7-a193-1c82b66bac4b</ClassSizeCollection_Guid><ClassSizeCollection_Label>78 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>6.5000000000000009</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>16</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>1a8f8496-adc4-4b07-829b-b38599a17630</ClassSizeCollection_Guid><ClassSizeCollection_Label>84 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>7.0000000000000009</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>17</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>45f8cc3e-0e66-4749-9a57-99821aadd70a</ClassSizeCollection_Guid><ClassSizeCollection_Label>90 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>7.5000000000000009</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>18</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>409389de-2f2e-4797-8f52-78043637bd1e</ClassSizeCollection_Guid><ClassSizeCollection_Label>96 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>8</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>19</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>ffbc0d56-2f09-46e4-8103-d476e91d9162</ClassSizeCollection_Guid><ClassSizeCollection_Label>102 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>8.5000000000000018</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><ClassSizeCollection><RowID>20</RowID><ParentRowID>1</ParentRowID><ClassSizeCollection_Guid>00c90832-0e79-40f2-b2d9-a3488fe52276</ClassSizeCollection_Guid><ClassSizeCollection_Label>108 inch</ClassSizeCollection_Label><ClassSizeCollection_AvailableForDesign>false</ClassSizeCollection_AvailableForDesign><ClassSizeCollection_InsideDiameter>9</ClassSizeCollection_InsideDiameter><ClassSizeCollection_WallWidth>0</ClassSizeCollection_WallWidth><ClassSizeCollection_MinimumBendRadius>0</ClassSizeCollection_MinimumBendRadius><ClassSizeCollection_JointDeflection>0</ClassSizeCollection_JointDeflection><ClassSizeCollection_UnitLength>0</ClassSizeCollection_UnitLength><ClassSizeCollection_Rise>0</ClassSizeCollection_Rise><ClassSizeCollection_Span>0</ClassSizeCollection_Span><ClassSizeCollection_BottomWidth>0</ClassSizeCollection_BottomWidth><ClassSizeCollection_RightSideSlope>0</ClassSizeCollection_RightSideSlope><ClassSizeCollection_LeftSideSlope>0</ClassSizeCollection_LeftSideSlope><ClassSizeCollection_FullArea>0</ClassSizeCollection_FullArea><ClassSizeCollection_BottomRadius>0</ClassSizeCollection_BottomRadius><ClassSizeCollection_CornerRadius>0</ClassSizeCollection_CornerRadius><ClassSizeCollection_TopRadius>0</ClassSizeCollection_TopRadius><ClassSizeCollection_BottomDistance>0</ClassSizeCollection_BottomDistance><ClassSizeCollection_RectBottomRadius>0</ClassSizeCollection_RectBottomRadius><ClassSizeCollection_RectTriangleTriangleHeight>0</ClassSizeCollection_RectTriangleTriangleHeight><ClassSizeCollection_PowerExponenet>0</ClassSizeCollection_PowerExponenet><ClassSizeCollection_ManningsN>0.013</ClassSizeCollection_ManningsN><ClassSizeCollection_KuttersN>0</ClassSizeCollection_KuttersN><ClassSizeCollection_DarcyWeisbachE>0</ClassSizeCollection_DarcyWeisbachE><ClassSizeCollection_HazenWilliamsC>0</ClassSizeCollection_HazenWilliamsC><DummyShapeType>0</DummyShapeType><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></ClassSizeCollection><IrregularClosed><Id>1</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>2</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>3</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>4</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>5</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>6</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>7</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>8</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>9</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>10</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>11</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>12</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>13</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>14</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>15</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>16</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>17</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>18</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>19</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><IrregularClosed><Id>20</Id><IrregClosedDepthWidthCurveCount>0</IrregClosedDepthWidthCurveCount></IrregularClosed><HMIMetaData Guid="70e1aa91-8e31-45fb-9347-2e82f53b1929" DateModified="2022-05-11T11:35:17.5829713-05:00" SchemaVersion="5.0.0.14" EngineeringLibraryType="CatalogConduitLibrary" /></NewDataSet>
I'd look at setting up the conduit catalog something like this:
The "Label" for each pipe as shown above will then show up in the "Size" column in the conduit FlexTable.
Further, if you go into the Material library and create separate materials for each class of pipe (see bottom of above screencap for example), then you can get the quantities for each pipe size and material totaled up automatically in the "Conduit and Pressure Pipe Inventory," available on the "Report" tab in the ribbon.
Answer Verified By: Dick Schneider
size" column does not appear in the conduit flex table
Dick, click the yellow Edit button at the top of the Flextable, locate "Size" on the left side (available columns) and click the single arrow in the middle to move it to the right side (visible columns). See: Customizing FlexTables for viewing and reporting data
Thanks Jesse I get confused with Catalog table (no column edit) and flex table (column edit).
