Hello : I m using for sewage and drainage system, i have query that calculated diameters for sewage system i only want to design ground levels and inverts levels without change , added manually is it possible to design only ground & Invert Elevations without Software calculated diameters,
Hi Nabeel,
I have moved your post to the OpenFlows forum.
I assume you are referring to the constraint-based design functionality with the GVF-Convex solver in SewerGEMS. First, ground elevations are not part of the set of parameters that the program can adjust as part of the constraint-based design. It can adjust inverts of structures and pipes, but the ground elevation is fixed and should be populated first (it is the basis for cover constraints for example). If you have a terrain model you can import it and assign ground elevations using Terrain Extractor.
If you only want constraint-based design to adjust pipe and structure inverts while keeping the pipe sizes (diameters) the same, see the following article: Design conduit inverts without changing conduit diameter
hello,
i have terrain and ground elevations are updated and also diameters in user defined conduits i just want to design there inverts without changing diameters,
Hello Nabeel,
In that case, what Jesse suggested about constraint based design to design inverts only, with ground elevations and pipe diameters data already entered should work for you, please follow steps provided in wiki earlier to not change the diameter while designing invert levels.
Sushma Choure
Bentley Technical Suppport
