Is it possible for me to copy data from within the modelbuilder preview so that I can paste it in a excel sheet? I know it is possible to coppy from flextable but i want to know if it is somehow possible to copy from the modelbuilder preview. See following image:
Hi Christen,
Yes you can copy the data values (but note that the column headers will not be copied).
1) Click the row header area to select the first row (see screen capture).
2) Hold down [Ctrl] + [Shift] and press the [Down Arrow] key (to select the remaining rows).
3) Press [Ctrl] + [C] to copy the selected rows to the clipboard.
Rob.
Answer Verified By: Christen Crique
I noticed something else. When I click the row header (see image below red square) som of the data changes (see yellow rectangles in image below). My question is then why does this happen?
When you click a column header it sorts the data by that column.
