Importing multiple demand values to one unique meter ID in WaterGEMS
Hello! I am trying to import demands to customer meters in WaterGEMS. Within the billing data I want to use for demand allocation, some of the meters have multiple demand values with different usage rate codes. For example, in the image below, 1000026837_14WOOD DUCK may have one demand value for Residential usage and one demand value for Irrigation usage. I would like to import demands and match them to their respective meter IDs without losing the data on the meters with multiple demand values. Is there a way to do this as part of an automated tool or process, or is the only way to do this manually?
Thank you in advance!
Olivia
