Is it possible to create a scenario with less nodes then the base scenario:
(See following image). Let’s say I want to create a scenario (Scenario J-1 gone) where P-1 and P-2 are are a single pipe so in other words remove J-1. Is that possible or can you not eliminate elements in scenarios?
I think I figured it out I drew a extra connection between T-1 and J-2 without J-1 in it. And in each scenario a deactivate the unwanted pipe and junction setup. As far as i know that's the only way to do that.
I concur with Rob - the way you describe is how you would accomplish what you are looking for.
Elements cannot be deleted in a specific alternative only and cannot have their from/to connectivity changed. Rather, you would utilize Active Topology to turn elements on and off to accomplish what you need. (a single pipe active in one scenario while the string of two pipes are active in the other).
See more here:
Is it possible to delete an element from one scenario, but retain it in another?
Active Topology Management
