Custom Label Size in SewerGEMS
Is there a way to customize text size in sewerGEMs? I am trying to get the label text size for each manhole to be large enough to see in various Map Views. I am having an issue because if I zoom in close enough to read the labels it is hard to see where I am in relation to the other manholes and pipes in the model. I also do not want a ton of map views in the report.
Here are some pictures for reference:
Where I want legible label text:
How far I have to zoom in to read text:
Courtney
Parents Reply
  • Courtney, note that those zoom dependent visibility settings will enable you to use GIS style visibility for annotations when zoomed in, while preventing the drawing pane from getting overcrowded when zoomed further out. You may need to experiment a bit with the values for your particular model.
    Jesse Dringoli
    Bentley Systems, Inc.
