All elements are not displayed after running model builder
I recently found a problem while using the model builder. I have already done every steps required in model builder and then I clicked finish and succeeded, but all elements are not displayed eventhough when I open the flex tables, all the data are already imported on water gems. Active topology in all elements are already actives. Also i cannot draw pipe or junction in the drawing pane. Do you guys have any suggestion or facing similar problem and how to solve it?
Thank you.
  • Hello Adhitya,
    Are you facing this issue for a single model or for all the models? What version of WaterGEMS are you using, File > Help > About WaterGEMS?
    Do you see anything happening when you click on Zoom to?
    Do you have background layer applied?
    Check junction flextables for "NaN", "infinity" or a very large number for the X/Y coordinates, if that is not the case then try following,
    • Compact database, File>Database utilities>Compact Database
    • Copy only .wtg & .wtg.sqlite files to a new folder and open model from new location.
    • File>Import>WaterGEMS Database into a new file.
    If none of these help, below are some troubleshooting steps to follow in this case.
    Drawing pane is blank or empty - no model elements appear
    Sushma Choure
    Bentley Technical Suppport
  • Hello Sushma, thank you for your time.
    I currently use WaterGems 10.03.05.05.
    I alrd use zoom extent and still no drawing showed.
    This is the junction flex table, which contain a lot of data error, I already followed all of the troubleshooting steps but nothing seems to fix my problem. The interesting part of this problem is at first five minutes after I load the model builder, the drawing are shown in the drawing pane and I was able to do some data cleaning. But after a while, the drawing is not shown anymore. I tried to load a new model builder on the different wtg file, but the same problem seems to happened all the time.
  • Hello Adithya,
    As seen in the flex table there is "infinity" seen for the X/Y coordinates. You need to fix the coordinates of these nodes (right click the row header > zoom to > change the X or Y in the properties) or delete the element (right click > zoom to > right click in the drawing pane > delete). See solution no. 5 from wiki provided to you earlier - Drawing pane is blank or empty - no model elements appear .
    Before importing data using Modelbuilder first check the data for any invalid data entries to avoid this problem. If this doesnt help then we can discuss offline your workflow.
    Sushma Choure
