My sewer cad mode is have large dia sewers whats the reson behind this SEWER FINAL CALCULATIONV_03.stsw
Mohammed Murtaza,
We will also need your .sqlite database file (with the same name as the model) in order to open your model for analysis. If you don't see it in File Explorer, make sure to turn on the View option to see file Extensions.
Please provide the file named SEWER FINAL CALCULATIONV_03.stsw.sqlite
Thanks,Larry
You can also use the File - Save to Package utility to zip all necessary files together and upload them using this link -
https://bentley.sharefile.com/r-r71f6668b9ca4cf39
Be sure to reply back here to let us know the name of the zip file you uploaded!
Are you doing constraint based design , with analysis type - design in calculation option?
Please note that the automated design feature has to satisfy multiple constraints like cover, capacity, velocity, slope, section size limit etc..
Read more about order of constrained based design priorities, for your reference.
Order of constrained based design priorities for StormCAD (GVF-Rational) and SewerCAD (GVF-Convex)
As mentioned by Larry you may upload database file as required.
Sushma Choure
Bentley Technical Suppport
One more thought to add: if you wish to prevent constraint-based design from using larger sizes in order to meet design constraints, you can use the "limit section size" option, or uncheck large sizes in your catalog class per this article: Limiting conduit design to only certain sizes
