Import autocad to watergems
Hello
When I import the .dxf file to the WaterGEMS Software, the node in AutoCad is incorrectly recognized as polygon (and Entity column set Area) (first picture) and I cannot define it as a Junction(second picture).
How can I fix the problem?Is there a way to solve this problem in the WaterGEMS Software?
I think the problem is that in AutoCAD, the junction should be defined as points. but how?
How to define a point  in AutoCAD ,that has the ability to become a junction?
Parents Reply Children
