In my pipe flextable i see what junctions are connected to each pipe. If I copy the junctions connected to a group of pipes in the pipe flextable, is there a away that I can use the data I copied to filter in the junction felxtable. I can not use the the NOT Like method because I would have to enter he code for each copied junction and the junctions are simply to many for me to do that.
I think might be able to use excel to right the NOT LIKE query for all the copied nodes. Just thought of that. But is there an easier way?
Hi Christen,
There is an "IN" operator that may work for you (which takes a comma delimited list).
Label in ('J-1', 'J-2', 'J-3', 'J-4', 'J-5', 'J-6', 'J-7')
Another possible way to go:
Rob.
Answer Verified By: Christen Crique
