ORD Drainage and Utilities Set Invert to Start/Stop vs Design Start/Stop Invert
Can someone please explain the difference between the Set Invert to Start/Stop toggle (true/false) vs the Design Start/Stop Invert toggle?  Also, If I need to set a pipe size do I have to start inputting the inverts from that point or will the program adjust the inverts.
  • Also, If I need to set a pipe size do I have to start inputting the inverts from that point or will the program adjust the inverts.
    If you have "set invert to start" and "set invert to stop" set to True as Scott mentioned, you would only need to enter invert elevations in the nodes (manholes, catchbasins, transitions, outfall) and the pipe inverts will pick up on the node inverts automatically. If you want the constraint based design solver to set both the node and the pipe inverts for you based on constraints like slope, velocity and cover, you can specify which element(s) have a fixed elevation, around which the solver will design the other inverts. For example if you know the outfall's elevation and want everything else to be designed around that, choose "false" for "Design structure elevation" in the outfall properties, then enter the ground and invert elevation. Make sure the other node elements also have a ground elevation set (it will only design inverts, not the ground elevation). Here are some resources that may help you:
    Constraint based design only on certain elements
    Tips for constraint-based design
    Jesse Dringoli
    Bentley Systems, Inc.
Reply
    Jesse Dringoli
