I am working with the integrated version of Watergems for Arcgis Pro and i am encountering an Unexpected XML error while doing the " Add joins " command.
This does not happen all the time. It works perfectly sometimes and other times no matter what, the join will not work.
Any solution for this ?
Hello Farah, here are a few questions to start troubleshooting this issue:
I am using ArcGIS Pro 2.8.7 integrated with Watergems 10.03.05.05.
The issue occurred to me on multiple models and not one only. Sometimes on the same model it works until it reaches a stage where the join is not complete and gives the same error.
I have always tried the suggested workarounds like creating the file in a different location or deleting the intermediate geodatabase. the problem is that it works sometimes and other times it doesnt for the same model after more than one repetition.This made me curious about the reason causing this "Unexpected Error"
Thanks for the information. Intermittent issues can be challenging to troubleshoot. There may be some specific sequence of events that causes the join to fail.
Is your hydraulic model, .GDB and .APRX stored in the same folder, on your local hard drive? (or a network location?)
I will send you a private message about the latest cumulative patch set for WaterGEMS 10.03.05.05 in case it helps (the patch log only indicates one fix related to ArcGIS Pro though it may not be related to what you're experiencing).
I will also discuss with our developers for other ideas.
Also - can you please provide a copy of your WaterGEMS log file for review? See: Locating OpenFlows product error log file
