Display Volume graph at the outfall
In SewerGEMS; I am still facing a very long time to display the volume at the outfall at end of the simulation, after sliding the timer to the end then I do right click on the outfall (O-15) in scenario "FEH_50 YRS 1440" that scenario run for 10 days. the program is responding after a very long time.
This problem still exists in spite of applying the latest Patch received (Patch 48) and deleting the results after moving the model to a C drive (SSD).
I have noticed that running that scenario only will make the model folder size (10.5 GB), it is really very big and hope to consider decreasing the size in future development.
The model copy is uploaded.
Mohamad Azzam
  • Mohamad, I am able to reproduce the problem with this model (but not with the other model). I will discuss with our developers and get back to you shortly.
    Jesse Dringoli
    Bentley Systems, Inc.
  • Mohamad, just a quick update - this new model you provided has many more timesteps than the other one (the duration is set to be much longer) which is part of the reason why the problem still occurs. We are working on a possible fix and will let you know when we have an update. Thanks for your patience.
    Jesse Dringoli
  • Hello Jesse - Thank you for the update and follow-up for the case. Yes this model is large and little complicated, also it requires a long run duration and more timesteps as you mentioned, that why we highlighted this issue and the enhancement will be very beneficial when we/ Municipality deal with the big Master Plan.
    We are waiting the solution and the improvement once it is ready.
    Appreciated,
    Mohamad
  • Hi Mohamad, I have sent you a private message with an updated patch. Please see the details in my private message.
    Jesse Dringoli
    Answer Verified By: Mohamad Azzam
