Hello, i'm configuring a MOHID 3D hydrodynamic model for an estuary. I want to introduce salinity and temperature from global model HYCOM as open ocean boundary condition (it is already configurated with sea level from HYCOM+FES). The HYCOM solutions are 2D and my grid is 3D with 10 layers. So, the way i try to do it was, first i converted the HYCOM solution to 10 layers (i just repeat each layer) and then i converted it to HDF5 file. I started imposing only salinity boundary condition and my water properties file looks like this (only the salinity section):
<beginproperty>NAME : salinityUNITS : psuDESCRIPTION : No description was given.INITIALIZATION_METHOD : HDFFILENAME : ../data/salinity_temperature_RPtideV3.hdf5DEFAULTVALUE : 38.!DEFAULTBOUNDARY : 38.REMAIN_CONSTANT : 0!BOUNDARY_INITIALIZATION : EXTERIORBOUNDARY_CONDITION : 2SUBMODEL : 0OLD : 0FILE_IN_TIME : HDFFILENAME : ../data/salinity_temperature_RPtideV3.hdf5SCHMIDT_NUMBER_H : 0.2SCHMIDT_COEF_V : 0.2ADVECTION_DIFFUSION : 1DISCHARGES : 1DISCHARGES_TRACKING : 0VERTICAL_MOVEMENT : 0SURFACE_FLUXES : 0BOTTOM_FLUXES : 0DATA_ASSIMILATION : 0PARTITION : 0WATER_QUALITY : 0TIME_SERIE : 1BOX_TIME_SERIE : 0OUTPUT_HDF : 1STATISTICS : 0<endproperty>
I've already check that the hdf5 file is correct, but when i run the model it shows errors like this for many grid cells
Property : salinity Negative initial concentration in cell 61 322 1 New concentration = 33.9384472301960 CheckFieldConsistence - ModuleWaterProperties - WRN02
and at the end it says
Property salinity solution is read from file. CheckOptionsSolutionFromFile - ModuleWaterProperties - ERR01
Any idea about why i'm getting this error or if there is another way to impose a time serie salinity and temperature condition in each open ocean boundary cell??
sorry for my english, i hope i was clear with my problem, I would appreciate any suggestion,
Michelle
