Surge Tank Location
Dear Bentley Team,
I would like to ask location of surge tank. I am supplying water through pumping. There are high and low points in pipeline profile. Picture is attached. If I provide surge tank near pump station then low would be critical as water will come from upstream and downstream both.
Should I provide two surge tanks, one near pumping station and one at low point about 5km far from pump station in order to protect pipeline.
communities.bentley.com/.../HGL-Profile.PNG
Regard,
SA
