ref: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/231714/implement-bacteria-and-ciliates-in-openflows-flood/
Hello, I'm currently working with water quality simulation too and also got this message "forrtl:severe (157): Program Exception - access violation image". Did your problem solve? And may I know how you solved it? Thank you
Could you provide a bit more information about the model setup please? If can follow the instructions mentioned above and send the project files.
Thanks and regards;Luis
Please note that since this is a separate issue I have split this to a new separate forum thread. As Luis mentioned, we will need a bit more information in order to assist you.
It solved with this explaination https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/54066/lagrangian-model-output-results, Thank you
