I am trying to add previously made local storm event to model catchment. After I select ""edit StormEventGroup", I select existing storm. What next to make it show in the Catchment properties window?
Hello Dick,
In the properties or flextables, you will set "Use Local Rainfall?" to True. You will then be able to assign a storm in the properties or flextables. This link includes information related to use global storms and local storms in the same scenario: Using Local Storm Events to Model Multiple Storms in a Single Scenario. This uses flextables as an example, but the local storm settings and input can also be done in the catchment properties grid.
Scott
