Hello, where can I find information about creating a nested system 1 and 2. They told me that in a level 1 nested system I should run the model only propagating the tide and then in a level 2 nested system the tide information is received and there I add wind, currents and temperature. But I don't know where to start to do such a thing.
There are several ways of setting a nested model system using the MOHID Water engine in OpenFlows FLOOD.
Could you let us know a little more about what type of problem are you trying to solve? Is it coastal flooding? What data do you have available to setup your model?
This would help providing you some guidance.
Kind regards,Luis
Hello, Luis
My work consists of a dynamic downscaling from the output of the MPI-ESM-MR model of CMIP5 (2006-2100) for the surface circulation of the Gulf of California in 2D and also to observe the distribution of plankton. This to evaluate the effects of climate change on the circulation of the Gulf and the distribution of plankton.The circulation in the Gulf is strongly influenced by the tide, the wind and the exchange of heat fluxes with the atmosphere.Create an atmospheric forcing HDF5 file with the variables: air temperature, wind speed (x,y), relative humidity, precipitation, cloud cover and solar radiation.For the initial conditions at the surface I have the variables: sea surface temperature, sea surface salinity, sea level height and current speed (x,y). For the biological variables whose distribution and concentration I want to observe over time, I have chlorophyll concentration data only from diatoms (large cells) and chlorophyll only from cyanobacteria (small cells).
Thank you for your reply. Please keep in mind, that to perform a downscaling for future projections you'll need boundary conditions for that period (2006-2100), including meteorological forcing and biogeochemical data.
You mention that tide is important. Does the MPI-ESM-MR solution includes tide, or just general low frequency circulation (density gradients and low frequency atmospheric forcing)? If it does not, then the "sea level height" you mention is actually "sea level anomaly", right?
To be able to use MOHID Water in OpenFlows FLOOD to downscale from a global solution with no tide, and add tidal forcing to the solution, you'll first need to setup and validate a tide model of the gulf of California. Have you done yet?
You can use the instructions described in this article.
I'll wait for your feedback.
Thanks Luis,
Yes, the variables that I mention come in the same time window.Regarding the variable 'sea_surface_height_above_geoid', it is not clear to me how to interpret it because they name it that way and my first impression was that it refers to the height of the surface of the sea level, I am not sure if it is an anomaly, are you sure that would it be an anomaly? And about adding the FES2014 file to the tide module, yes, I already did.
Hello
Typically large scale/global solutions ignore tide, because it's only important/relevant near the coast and over the continental shelf, in terms of general hydrodynamic circulation.
I don't know the MPI-ESM-MR solution, so you'll have to read its documentation to understand what exactly is "sea_surface_height_above_geoid", i.e. does it consider tide or not? My guess it's not, but please make sure before I can suggest guidelines to continue.
Thanks and regards,Luis
