Hello LuisI've tried following the guide https://communities.bentley.com/products/hydraulics___hydrology/m/hydraulics_and_hydrology_gallery/274390, but I've some trouble when adding the drainage network map. It does not appear like the tutorial even I've changed the layer style properties. Is there any solution?Best regards
Possible solutions for the drainage network map not appearing are:
1) Check the drainage network layer properties and increase the base width to 1000 (or more).
2) The drainage network HDF5 results file does not contain information about the coordinate system it's in. Please remove the layer and re-add it again to the map. When you do that a dialog appears where you can choose the coordinate system. By default, for drainage network HDF5 file it will be set to "None". I believe in this exercise it should be "Geographic" -> "World" -> "WGS1984"
Please let me know if this solves the problem. Thansks and regards,Luis
HelloIt solved, the drainage network now appearing after increase the base width to 10000, Thanks and regards
We split this post to a new thread since it is a new issue and for ease of searching for other users with a similar issue.
Scott
