How should I install a macrometer at the entrance of a DMC?
As far as I know, there currently isn't a specific element in WaterGEMS to incorporate a flow/pressure meter. We usually model them as GPV's with a negligible headloss, and then attach the appropriate scada elements (flow/pressure etc.) to the GPV.
You're right Joeri. If the head loss is negligible, you can make it a GPV, TCV, junction, hydrant,... and then attach SCADA elements to it.
Entendi, no caso devo inserir um GPV com perda de carga insignificante para simular um medidor de fluxo na entrada do DMC.
See related article here which has the same suggestion: Modeling devices and components that are not explicitly available as an element
Ver artigo relacionado aqui que tem a mesma sugestão: Modeling devices and components that are not explicitly available as an element
