Submersible Pumps
Hi!
I need help about modeling a submersible pumps, i don't know what elevations insert on Reservoir and pump. for the exemple my dynamic level it's 38 meters, the closest node it's on elevation 235,00, can you help me define the elevations of my reservoir and pump? Do i need to change the length of the pipes on 'Has User defined length'?
