Using customer meters for calibration
If you only use customer consumption to calibrate the hydraulic model, what can happen in the calibration?
  • If you assume that all of the discrepancies between the model and the field data are due to customer consumption, you may miss serious errors in data collection, pipe roughness, connectivity,... The key to calibration is determining WHY the model and field data differ and fixing that issue.
    Sometimes you may improve calibration for a single data set by adjusting the wrong parameter but this will give you a worse model and it will show up in other data sets. This is what I call "Calibration by compensating errors."
    Here is a list of some of the reasons that calibration might need additional work. How confident are you that all of teh discrepancies are due to consumption?
    Physical
    Pipe size/location
    Pipe connectivity
    Pipe roughness
    Pressure zone boundary
    Pump curves
    Pipe material/age in GIS
    System changes since model built
    Elevation data
    Operational
    Valve open/closed/throttled status
    Control valve operation/settings
    Transient events
    Actual operations not matching control rules
    Unusual operations when data were collected
    Tank water levels
    Pump status/speed
    Lack of sufficient sensors/gages
    Water quality reaction rates
    Demands
    Spatial allocation
    Model does not reflect conditions when data collected
    Large customers with atypical demand patterns
    Not accounting for seasonal changes in demand
    Data
    Inaccurate/uncalibrated gages/meters
    “Latched” data from SCADA
    Understanding SCADA data – average vs. instantaneous
  • If you use the flow provided together with the consumption of the customers' meters, will the model understand that the difference could be water losses?
  • With the leak detection feature in the Darwin Calibrator tool in WaterGEMS, you can specify measured/observed flow and pressure and the tool will take that information along with the model network and entered demands (whether they are from customer meters or directly on junctions) and will attempt to determine the location of leaks by trying emitter coefficients (pressure dependent demands) at various locations until the model results closely match the observed/measured values. See more here:
    Performing Leakage Detection Using Darwin Calibrator
    Tips for Water Loss Management and Leak Detection
    Water Model Calibration Tips
    Jesse Dringoli
    Bentley Systems, Inc.
Reply Children
