Demora para rodar modelo no sewergems
Construi um modelo no SewerGEMS e ele está demorando muito para calcular (estou usando o motor de cálculo GVF-Convex).
As cargas foram carregadas pelas propriedades (casinhas). O modelo é grande, tem 320km de redes e várias saídas de redes (54 no total).
Ele roda sem erros, porém está demorando demais. Cerca de 1,5 hora.
Algum tem alguma sugestão ou alguma dica do que possa estar acontecendo?
Obrigado!
  • Complementando: estou rodando no estado estático.
  • Are you able to converse in English?
    1) What version of SewerGEMS are you using? Check under File > Help > About. The latest is currently 10.03.04.53. If you using a much older version, try upgrading:
    Downloading OpenFlows Software
    2) Are you seeing any messages when you use the Validate command, or any messages in the User Notifications window after computing? Check these for clues as to what the model may be struggling with.
    3) Is the model taking a long time to open and save? If so, the problem may be with the save of the model database due to change tracking see:
     SQLITE database size grows very large due to Change Tracking
    4) In the Calculation Summary, do all subnetworks indicate that "convergence was achieved"? If you see any with "NOT achieved", this is an indication that the numerical solver is struggling to settle on a balanced solution which can take longer to solve as extra iterations are needed. Also if you have pressure subnetworks, check the pressure tab of the calculation summary and ensure that the network is not unbalanced for any pressure subnetworks. See:
     Convergence NOT achieved Message when computing StormCAD or SewerCAD model
     Improving calculation performance (run time) for a SewerGEMS or SewerCAD model
    5) How many conduits, pressure pipes and pumps are in the model? Do you have any other complications included?
    6) What are your computer specifications? (CPU, RAM, operating system, etc). Have you tried using performance monitor in the Windows task manager to ensure that you are not running out of memory? (which will cause a slowdown).
    7) Can you confirm that you have adequate storage space on the drive that the model is saved to? Ensure that it is not stored on a network drive and that your Windows temporary folder (or custom results file path, if used) is also not mapped to a network drive. Using a Solid State Drive (SSD) is recommended for performance reasons. See:
     How to increase model performance / reduce run time (recommended minimum system requirements)
    8) Does the same problem occur if you copy just the .STSW and .STSW.SQLITE files to a new folder on your local hard drive?
    9) If none of the above helps, can you provide a copy of the model with steps to reproduce?  Sharing Hydraulic Model Files on the OpenFlows | Hydraulics & Hydrology Forum
    Em português:
    1) Que versão do SewerGEMS está a utilizar? Verifique em Ficheiro > Ajuda > Sobre. A última é actualmente 10.03.04.53. Se estiver a utilizar uma versão muito mais antiga, tente actualizar: Downloading OpenFlows Software
    2) Está a ver alguma mensagem quando utiliza o comando Validar, ou alguma mensagem na janela Notificações do Utilizador depois de computar? Verifique estas para obter pistas sobre o que o modelo pode estar a debater-se.
    3) O modelo está a demorar muito tempo a abrir e a guardar? Em caso afirmativo, o problema pode estar com a salvaguarda da base de dados do modelo devido ao rastreio de alterações ver:  SQLITE database size grows very large due to Change Tracking
    4) No Resumo do Cálculo, todas as sub-redes indicam que "a convergência foi alcançada"? Se vir alguma com "NÃO foi alcançada", isto é uma indicação de que o solucionador numérico está a lutar para se estabelecer numa solução equilibrada que pode demorar mais tempo a resolver, uma vez que são necessárias iterações extra. Também se tiver sub-redes de pressão, verifique o separador de pressão do resumo de cálculo e assegure-se de que a rede não está desequilibrada para qualquer sub-redes de pressão. Ver:
    5) Quantas condutas, tubagens de pressão e bombas estão no modelo? Tem outras complicações incluídas?
    6) Quais são as especificações do seu computador? (CPU, RAM, sistema operativo, etc.). Já tentou utilizar o monitor de desempenho no gestor de tarefas Windows para garantir que não está a ficar sem memória? (o que irá causar uma desaceleração).
    7) Pode confirmar se tem espaço de armazenamento adequado na unidade em que o modelo é guardado? Certifique-se de que não está armazenado numa unidade de rede e que a sua pasta temporária do Windows (ou caminho de ficheiro de resultados personalizados, se utilizado) também não está mapeada para uma unidade de rede. A utilização de uma unidade de estado sólido (SSD) é recomendada por razões de desempenho. Ver:  How to increase model performance / reduce run time (recommended minimum system requirements)
    8) O mesmo problema ocorre se copiar apenas os ficheiros .STSW e .STSW.SQLITE para uma nova pasta no seu disco rígido local?
    9) Se nenhum dos anteriores ajudar, pode fornecer uma cópia do modelo com passos para a sua reprodução?  Sharing Hydraulic Model Files on the OpenFlows | Hydraulics & Hydrology Forum
     Traduzido com a versão gratuita do tradutor - www.DeepL.com/Translator
    Jesse Dringoli
    Bentley Systems, Inc.
