I used the big map to draw the hydraulic network in watergems but the scale is from 1cm to 10m , how do I change the scales?
Hello Gilvandro,
Can you please elaborate on the issue? What do you want to change?
If you want to change the units then Go to File > Options > 'Units and formatting', and change the unit. The following link might help you -
(+) Changing units and decimal precision in Properties, Flextables, graphs or profiles - OpenFlows | Water Infrastructure Wiki - OpenFlows | Water Infrastructure - Bentley Communities
conforme consta no desenho da rede hidráulica o comprimento correto é 100m mas na janela de propriedade do watergems é 10m, como faço para corrigir a escala?
Gilvandro,
There is not a way to automatically change the scale of a model, as this would involve scaling not only the lengths, but the position of all tne nodes and pipe bends. There are a few other suggestions in this article: How to move, scale or rotate a model to the correct location?
Note that I tested this in a new model in the latest version of WaterGEMS by inserting a Bing Map with the default settings, then used the pipe layout tool to trace over a road in Brazil and compared it to the same road on maps.bing.com and the length appeared to match. So, I suspect there may have been a problem with the way that you configured your Bing Map. Did you enter custom 3-point or 1-point control points? (select the Bing Map in the background layers and click the edit button to check). Also, are you using a recent version of WaterGEMS? (check under File > Help > About) The latest version is currently 10.04.00.108.
You may need to start over with a corrected Bing Map (draw a single pipe over a road to confirm the correct scale first), or consider one of the options in the Wiki article mentioned above.
Em português:
Não existe uma forma de alterar automaticamente a escala de um modelo, uma vez que isto implicaria escalar não só o comprimento, mas também a posição de todos os nós e curvas de tubos. Há algumas outras sugestões neste artigo: How to move, scale or rotate a model to the correct location?
Note-se que testei isto num novo modelo na última versão do WaterGEMS inserindo um Mapa Bing com as configurações padrão, depois utilizei a ferramenta de traçado de tubos para traçar sobre uma estrada no Brasil e comparei com a mesma estrada em maps.bing.com e o comprimento parecia corresponder. Portanto, suspeito que possa ter havido um problema com a forma como configurou o seu Mapa Bing. Introduziu pontos de controlo personalizados de 3 pontos ou de 1 ponto? (seleccione o Mapa Bing nas camadas de fundo e clique no botão de edição para verificar). Está também a utilizar uma versão recente do WaterGEMS? (verificar em Ficheiro > Ajuda > Sobre) A versão mais recente é actualmente 10.04.00.108.
Poderá ter de começar de novo com um Mapa Bing corrigido (desenhar um único tubo sobre uma estrada para confirmar primeiro a escala correcta), ou considerar uma das opções no artigo Wiki acima mencionado.
Traduzido com a versão gratuita do tradutor - www.DeepL.com/Translator
