Pump Definition Type
I'm trying to use "Depth Vs Flow (Type2)" pump definition for my model which is being simulated with Explicit solver. In the definition table, I'm not clear what is it meant by depth.
is it flow depth in the wet well with which the pump is being connected with? Say my pump is connected with 3m deep wet well, then what is the maximum depth that we should mention definition? Is it 3 m?
Flow (L/s) Depth (mm)
0 0
10 10
10.5 3,000.00
Thanks & Regards
Nishadi
