the warmest greetings to you all! how are you doing? Hoping fine and healthy.
Today I get a trouble while printing 30cum service reservoir. I prefer taking the standard drawing. However, the drawing has a hatch and this hatch makes my printing invisible and difficult to understand. I know it is very simple and easy for you. Am looking forward for your help
I attached my drawing hereunder30cum Circular Water Reservoir.DWG
with regards
Are you using a Bentley product such as WaterCAD or WaterGEMS? It appears that you only attached a DWG file. If you are using WaterCAD or WaterGEMS for AutoCAD, please also include the .WTG and .WTG.SQLITE files, zipped.
If you are not using Bentley software, you will need to contact Autodesk for help with the hatch issue.
thanks
