The model I have has many of the profiles created by Auto Create Profiles, we need to export them to CAD format, however that will be one by one, is there away to export all the profiles from the list to one cad sheet?
The second request is: we prefer to export the profiles to civil 3D format (to use part list), or if provide an option to export the profile list alignment; meaning for each profile (from "Manhole Name" To "Manhole Name") as a single alignment so when export the network to shape files and import it to the civil 3D so the alignment will help us to produce profiles in the civil 3D.
Mohamad Azzam
Hello Mohamad,
Profiles currently will need to be exported one at a time. This link on profiles has information on this: Options for creating, viewing, and exporting profiles.
I can put in a request for an option to have additional export formats. If this is included, it will be in a future release of SewerGEMS.
Scott
So you know, both of these are logged as enhancements (bulk export: 1062672, export to Civil3D formats: 1062594).
Another option may be to use WaterObjects.NET to create a tool to do a bulk export. More information on WaterObjects can be found here: WaterObjects.NET - Extending the capabilities of your OpenFlows product .
Regards,Scott
Answer Verified By: Mohamad Azzam
Thank you Scott for considering our request and logging a request.
Unfortunately I did not work on WaterObjects for developing that tool. if possible from your end will be grate.
