the volume of gas still increasing although the time period is being adjusted
Hello Amr,
I see you also created a service request for this issue. See the response there for some additional details on the issue. Once you set the Report Period to a non-zero number, the gas volume will still increase, but this is below there is water outflow for the entire model run.
Scott
See also:
