How can I use Darwin Calibrator to calibrate an EPS model in Watergems Connect 10.03.05.05? Shall I introduce different time snapshot for each time step and calibrate based on each snapshot? Are there any guidelines?
I am trying to use Darwin Calibrator to calibrate an EPS model with an average day diurnal pattern and hourly time step.
Hello Farah,
Darwin Calibrator is designed to work with an EPS model. Different field data snapshots are used to represent the time that the hydrant test was done. You typically have a few of these field data snapshots in a typical calibration study.
I would recommend reviewing the following wiki article for more information: Using Darwin Calibrator.
This includes information on the setup and use of Darwin Calibrator. There is also information on existing WaterGEMS sample files that have Darwin Calibrator studies already included. These can be used as guidance for the setup of your model.
Scott
