Hello everyone.
I have User User notification message id 41891 with my hidraulic model .
Please help me to resolve that. Tnaks all
I WILL UPLOAD THIS FILE HERE www.transfernow.net/.../20230118QlvxNAVo
I was looking at your model at the same time and I concur with Scott - the trunk pipes in particular (between "RESERVORIO EXISTENTE" and J-79) are too small for the flow demanded. If you take a look at a profile this becomes more clear:
This is a profile between "RESERVORIO EXISTENTE" and J-101.
If I increase the trunk main pipe diameters to 40 mm for example, the headloss is much less and the negative pressure problem no longer occurs:
I was able to solve the problem. thank you very much for your help
Answer Verified By: Larry Abla
