Hello! I'm following the steps of the pdf Quick Start - Urban Flood Simulation Apr20 but I have a problem importing the building.shp file. I tried to download the file and extract it again, but the error persists.Step 10:Error:
Hello Luis,
Can you please make sure that in the same folder where the Buildings.shp file you have the files: Buildings.dbf, Buildings.prj and Buildings.shx?
This could be one of the causes to the problem.
Thanks and regards,Luis
Answer Verified By: Luis Bergonzini
Ah, that was it. I had misunderstood when I read it in the material. Thank you very much!
