Hi, new WaterGEMS user here. I am having issues with the display of my water model from a client. Nothing shows up in the display pane, however, there is clearly pipe and junction data when I open the flex tables. I followed all the steps here, but it did not work:
communities.bentley.com/.../drawing-pane-is-blank-or-empty---no-model-elements-appear
I am not familiar with the file organization of WaterGEMS. Am I missing files? I have a .WTG file and a .WTG.SQLITE file.
Thank you!
Hello Adrian,
I see you also created a service request for this. I will email you from the service request with something else to try. Once there is a solution, I will follow up here in case other users run into a similar issue.
Scott
Just to follow up on this, this was related bad coordinates for a node in the model. This is Option 5 from this wiki article. Deleting the element would resolve this issue.
