Using the new version of SewerGEMS Version (10.04.00.158) takes a very long time to open the model, the opening always gets stuck at Schema Update as shown in the screenshot below
The model is uploaded at Bentley Sharing Files
Mohamad
Hi Mohamad,
Please refer to my answer on December 8th, 2022 in your previous thread here: Long Time to open The model_SewerGEMS
This is a one-time delay when opening models in the new version, as it needs to upgrade the model database to the new format. The Schema update takes a particularly long time in this case because the model was saved in a much older version. Once you re-save the model in the new 10.04 version, this long delay will no longer occur.
I checked with our developers and at this time we do not plan to investigate further performance improvements with this type of schema update, since it only impacts some model (others will be much faster to open) and only the first time the model is opened in the new version.
I have documented this (along with other reasons why models may take a long time to open, which do not apply in your case here) in the following new article in our Wiki: Opening an existing model takes a long time
Answer Verified By: Mohamad Azzam
