hello Bentley team
I put the set point flow of the FCV at 200 l/s but the following junction have demand 250 l/S
What is the downstream flow of the FCV in this case?
Hello Ahmed,
Is the FCV in the actual system you are modeling? If not, you may want to model the actual elements of the model. The following link has information on typical uses of an FCV in a model: Using a Flow Control Valve (FCV).
