How to use other hydrodynamic model data to driven an oil spill simulation
      I followed the instructions in https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/212220/openflow-flood-underwater-oil-spill?ReplySortBy=CreatedDate&ReplySortOrder=Ascending to run the oil spill model by directly reading currents/water level/ water tempearture .etc obtained from another hydrodynamic model by adding a MeteoOcean block in the Lagrangian data file like the following
<BeginMeteoOcean>
<<BeginProperty>>
DESCRIPTION : velocity U
UNITS : m/s
MASK_DIM : -99
<<<BeginMeteoOceanFiles>>>
..\General Data\Boundary Conditions\HYCOM.hdf5
<<<EndMeteoOceanFiles>>>
<<EndProperty>>
<<BeginProperty>>
DESCRIPTION : velocity V
UNITS : m/s
MASK_DIM : -99
<<EndProperty>>
<<BeginProperty>>
DESCRIPTION : velocity W
UNITS : m/s
MASK_DIM : -99
<<EndProperty>>
<<BeginProperty>>
NAME : wind velocity X
DESCRIPTION : wind velocity X
UNITS : m/s
MASK_DIM : 2
..\General Data\Boundary Conditions\Meteo.hdf5
<<EndProperty>>
<<BeginProperty>>
NAME : wind velocity Y
DESCRIPTION : wind velocity Y
UNITS : m/s
MASK_DIM : 2
<<EndProperty>>
<<BeginProperty>>
NAME : air temperature
DESCRIPTION : air temperature
UNITS : ºC
MASK_DIM : -99
<<EndProperty>>
<<BeginProperty>>
FIELD_NAME : mean sea level pressure
DESCRIPTION : atmospheric pressure
UNITS : atm
MASK_DIM : -99
<<EndProperty>>
<EndMeteoOcean>
However, I still got a message which asked me to add air pressure data in the Atmosphere_1.dat and water temperatue data in the WaterProperties_1.dat.
Could you tell me what's the problem with the upper setup?    Shall I only provide water level and U/V current data in the "MeteoOcean" block?
