SewerCAD CONNECT Edition Update 4 - Civil3D Integration issue
Dears,
I notice that whenever I attach or overlay an X-ref and save my model inside SewerCAD update 4 running within C3D 2023 (issue may replicate in other Haested product line and will be able to note that as we proceed with other project wet services models), the next time I open the model it shows error messages and suggest to recover the file which is of no use. Also if the recover prompt is discarded and the model is opened, the network is visible but not selectable. All data is still there in the database and can be seen in the Flex tables, but engineer cannot even select a model element.
If engineer manages to remove the x-ref (not straight forward as you may need to try couple of times while receiving fatal error and whole software crashes or need to try open the CAD version from the C3D only software without the SewerCAD integration and remove the X-ref from there and save and close and open and save and close a couple of times) to then restore the file and model functionality.
This behavior also repeats whenever opening models built with earlier versions, so for instance I have a  laptop that still runs the last CONNECT Update 3 version and i open the earlier models fine, but when i try to open the same model using the SewerCAD update 4 running within C3D 2023 it also shows a similar behavior.
Any clue one what is happening here?
